STB That offers remote eye?
windfall
Ok It may sound really obvious - what I am after is an STB that can do what the Sky+ does with remote eyes. So I can control the STB from another room.
Is there such a thing?
Tone
SamRadford
Yes, the original Grundig Ondigital models worked with a "magic eye". The lead wasn't very long. it was intended so you could control the unit when it was inside a cupboard. You might strike lucky and find a receiver and "eye" on eBay. The socket looked like a modem connection port.
Frankly, it would probably be better just to use one of the wired or wireless "remote extenders".
father alice
Have a look at a tvlink plus - works for sky plus 1 other device ( or 2 non sky devices)
there are others as Sam mentioned, or go wireless.
pablo99
One of these new freeview boxes designed to plug into the rear scart socket would have a magic eye unit.
You would then just have to extend it's cable length as desired.
Pablo
father alice
Actually just got a tvlink plus myself and well pleased - by connecting it to rf2 out on the sky box, the two ir senders allow 2 additional devices to be controlled, in addition to the sky box, so 3 in total, not the two that seems to be advertised.
If the cabling is already in place for tv link, it is well worth the £10 - £20 cost IMHO
SamRadford
I didn't see any limit mentioned. You can control as many pieces of equipment as you can fit in front of the two "eyes". Just point them generally towards the front panels.
