STB Control - what's better, Sat IR control or External Link?
Discussion in 'Blu-ray & DVD Players & Recorders' started by howardmg, Apr 14, 2005.
  1. howardmg
    howardmg
    Sep 13, 2004
    123
    Kingston, Surrey
    Would be interested to know what's better at controlling STBs, particularly changing the channels via a timer.
    I've read on this forum that Toshiba's Sat IR controller doesn't always work, and that the Panasonic external link is better? Is this true?
    Would also be keen to know how those of you with a PVR / DVD combination handle this. Do you just use the EPG / timer on the PVR to save to the PVR HDD, and then just link to the DVD for archiving? Or do you get the PVR to control the DVD? If the latter, does this need the external link?
    Thanks for any feedback.
  2. gmr
    gmr
    Feb 15, 2005
    46
    +3
    I have a Toshiba (XS32) and find the IR STB control works flawlessly. Not had one failure in hundreds of recordings. Easy and quick to set via the timer. Of course you have to be careful not to accidently change channel on the Sky box when recording - nothing is stopping you doing that. I have recorded 30 mins of my wife flicking around the Sky channels before!
    Gidon
  3. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I also have the XS32, and the IR works flawlessly with my Sony Freeview box (once I found out the code, from this forum).
    Neither system is perfect; I think it depends on the combination of boxes and how they work. For instance my Sony Freeview box doesn't have "Smartlink" on the RGB Scart; others do. Or if I had a STB box that the XS32 couldn't control, the IR would be useless.
    Mark
