static ip address?
Discussion in 'Xbox Forums' started by F Nikk, Mar 22, 2006.
  1. F Nikk
    F Nikk
    Feb 20, 2006
    163
    Birmingham
    +12
    hey guys i was just wondering whether i couldset the MAC and IP address of my xbox360 the same as my pc's because i dont have a router and dont like constanttly switching modem on and off. is it possible?
  2. Mike-M
    Mike-M
    Oct 13, 2004
    1,376
    48
    Lincoln
    +39
    Don't know anything about the Xbox, but a MAC address is unique to a given piece of hardware and not changable AFAIK.
  3. F Nikk
    F Nikk
    Feb 20, 2006
    163
    Birmingham
    +12
    cheers for reply. see with the original xbox live, you could set the xbox ip and mac address to exactly the same as the pc's so that you didnt need to unplug the router from the power switch in order for it to renew its adress. all you had to do was replace the broadband cable between the pc and xbox. im asking as i dont have a router abd dont want one lol
  4. colinwheeler
    colinwheeler
    Jul 12, 2005
    2,423
    Basel
    +153
    I don't believe that you can change the MAC address. Try just setting the IP address to the same and see if that works.
  5. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    You dont give much information. So I'll assume your using Cable?
    If so, yes, just set the xbox to auto and change the xbox mac address to be the same as your PC. You cant set the IP address as it will get a different one every so often.
  6. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    Londoner living in Bahrain
    +140
    Just as a side note:
    MAC addresses are perfectly changeable - assuming you have good drivers;) . We used to change our MAC addresses on our PC clients for our AS/400 security.
    Look at your network card (on the PC) and you *should* see a "Software MAC address overide" or similar. :thumbsup:
    On the subject of the x360.... no idea, sorry! :confused:
  7. Mike-M
    Mike-M
    Oct 13, 2004
    1,376
    48
    Lincoln
    +39
