StarWars query
Discussion in 'Movie Forum' started by BobHaymond, Oct 7, 2004.
  1. BobHaymond
    BobHaymond
    :clap:
    I have just obtained the StarWars Trilogy on DVD. Having been surprised all along that these fine special effects were NOT available on DVD. Being old and contrary [many years ago I was young and contrary!], I had decided not to get the newer episodes until after the first were available. So now I will get the others.
    Query: There are three notions of chronology which apply yo StarWars; i) date of release ii) position in the overall story and iii) the numeral applied to the episode. The latter two may well coincide as far as I know, but certainly they do not match the first. If yawl have worked this out I'd appreciate a road map.
    I might add, that I put together my home theater about two years ago using many posts on what to do. I've made few posts since because I have been overwellmingly satisfied with the result. Basically CambridgeSoundWorks Newton, top Onkyo, and a Sony XBR36.
    Thanks for any attention.
  2. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    As follows;
    The Phantom Menace 1999 No.1 Numeral I
    Attack of the Clones 2002 No. 2 Numeral II
    Revenge of the Sith 2005?? Mo. 3 Numeral III??
    A New Hope 1977 No. 4 Numeral IV
    Empire Strikes Back 1979 No. 5 Numeral V
    Return of the Jedi 1983 No. 6 Numeral VI
    HTH
  3. BobHaymond
    BobHaymond
    Thanks very much for the info--exactly what I wanted. :lesson: :lesson: I have not seen the Trilogy since they were original-- is there a preferred watching order amonogst Connoisseurs?
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Watching from episode I would be the obvious chronicological order to watch them, the only problem is that no one yet knows the blanks that are yet to be filled in, in Episode III.
    Otherwise, watching Eps IV, V and VI first is how most of us have previously viewed the trilogy.
  5. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    Just watch IV, V, VI. then rent I and II before seeing III at cinema.
    You can live without buying eps I and II. I is awful. II is slightly less awful.
  6. Tug100
    Tug100
    Oct 2, 2004
    20
    There is an ep which seems to be used by lots of home cinema shops to demo kit. Which one is it.
    And... I have the trilogy - which bits from the trilogy do you recommend for a great demo?
    Hope I'm not hijacking the thread too much!! :)
