Starting SonicStage a bit faster
Discussion in 'Headphones, Earphones & Portable Music' started by granbajo, Jul 25, 2005.
  1. granbajo
    granbajo
    I thought I pass this along since I have read a few complaints about how slow is SonicStage when it opens. It used to annoy me to no end that it always opened on the Connect Music Store, specially when I can't buy anything from Ireland anyway!
    After a lot of searching on the options menu to see whether I could start the application and go directly to my library, which I couldn't find, I discovered that if I ran Omhjbox.exe from the command line, it opened directly on my library.
    So I went to the shortcut in the start menu and removed any parameters. It now looks like this (I can't even remember what the parameters are anyway)...
    "C:\Program Files\Sony\SonicStage\Omgjbox.exe"
    It loads a bit faster and doesn't annoy me when it connects to the shop anymore!
  2. Pyrobob83
    Pyrobob83
    Great info there, though when I installed SS 3.1, that's the shortcut it gave me anyway - without any parameters. :thumbsup:
  3. Mike_manchester
    Mike_manchester
    I *think* i am right in guessing that SS opens with the last view that you had enabled - so if you were in connect store, it will launch with that.
    My version of SS has always gone straight to the library, but has launched into the transfer screen when i exited it there last.
