Starter Question - Barco 800 reliability modifications
Discussion in 'Projectors, Screens & Video Processors' started by bbmhs, Feb 3, 2005.
  1. bbmhs
    bbmhs
    Greetings from the frozen north,
    Appologies if this question has been answered in other threads, but my searchees really haven't come up with anything yet. I have a very low-hour Barco Data 800 that I got for a song. It has <1000 hours and the tubes are in decent shape (The blue has some wear, but its livable). I am currently using the projector, and it is fantastic.
    I have heard horror stories about catastrophic power supply (among other) failures due to component aging and bad solder joints; but no DIY information on how to inspect, and correct, these potential problems.
    Is there a list of things that I should do to my new-found projector? I've seen references to resoldering all the joints on major boards, but I need a little more direction that that. And while I've got these boards out for work, is there anything else I should do?
    Thanks in advance,
    Andrew
  2. arbey
    arbey
    Oct 8, 2002
    76
    It's always good to resolder the power suply, especially the two big transformers.
    For the rest, if it aint broke, don't fix it!
    Here is a site with a lot of information concerning barco 800:
    http://www.lynxxx.nl/barco/
    good luck!
  3. bbmhs
    bbmhs
    Thanks arbey,
    That will likely be my next project... If I can stop watching movies on it long enough to power it down.
