start up tray
Discussion in 'Desktop & Laptop Computers Forum' started by hamtaro, Jun 15, 2003.
  1. hamtaro
    hamtaro
    i have a problem trying to get rid of any trace of kazaa. its not physically in any of my programs but seems to be in my start up tray , how do i get rid of this?:lesson:
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    its a nuisance of a program isnt it!!!!
    Having removed any trace i could find of it, i also couldnt stop it mysteriously appearing (of course any attempt to exit it would then cause problems since it technically isnt there....). There has to be a more scientific method but if i recall i went into msconfig and stopped the kazzaa thing starting at boot up and from that located where the files responsible were hiding....... from there i had no more problems until the kind sibling who put it on in the first place decided to put it back :mad:
    ad
  3. nathan_silly
    nathan_silly
    In options of Kazaa, start up with windows.
    Also check the startup folder in the Start button.
  4. Pulsar
    Pulsar
    Jan 19, 2003
    2,925
    West Midlands - Stourbridge
    +292
    Try clicking on the start button, and open a 'run' window. Type 'msconfig' and press enter. Click on the tab on the far right. This shows you what programs are loaded on start-up, so just uncheck kazaa for example, then click apply. These settings will be initialised once the PC is restarted.
    Not sure if this is what you wanted, hope it helps.
    Rob
  5. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    If you've deleted all traces of it from your PC, but it's still "lurking" (which is what I think you're saying!), then I'd suggest downloading, and running a programme like Reg Cleaner. It sifts through your registry and searches for any invalid items that still exist - you can then choose whether or not to delete the offending items :) There's a chance that it's a "wayward" registry entry that's causing the problem :(
    I run this programme every now and then and it's amazing what items remain on your system after you get rid of them - a very worthwhile tool in my opinion :) :smashin:
    K.
  6. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    is this the full kazaa or kazaa lite?
  7. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Use registry editor (Start->Run-> Type in Regedit press Enter)
    Look for the following key:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
    Should be something like this:
    KAZAA C:\Program Files\KaZaA Lite\Kazaa.exe /SYSTRAY
    Delete the key.
    You can search the registry for any other occurrence of "KAZAA"
  8. Squirrel God
    Squirrel God
    Tip for the future:
    Always make sure you completely shut down the program you want to uninstall BEFORE you uninstall it ;)
