Starfield Ceiling on the cheap
Discussion in 'Home Cinema Building DIY' started by EvilMudge, Apr 2, 2003.
  1. EvilMudge
    EvilMudge
    Was at a family friends place recently, and noticed he has a starfield (looks like the night sky) on the ceiling of his nursery room.
    Given how much a fibre optic setup can cost, I asked him how it was done. So here goes.
    Artex stipple effect applied to the formerly smooth ceiling.
    Then a matte black coating put on with a soft roller brush so that it goes all over to create a non reflective surface.
    Then a coating of gloss white applied by hand with a small brush to a few spots - the beaty part is that you don't have to do it well, just dab away.
    I suppose if you were feeling particularly flushed with cash you could use glow-in-the-dark paint instead of gloss white.
    Anyway, it looks pretty good, given how cheap and easy it is.
  2. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Sounds good Mark.
    I recently painted a stipled artex ceiling with matt black. Unfortunately I wanted to black it all out. Took me absolutely ages to get rid of all the 'stars'. :mad: :mad:
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Artex? :suicide: That stuff is evil.
    Previous owners of my house loved the stuff, it's over loads of walls and ceilings. How hard is it to get off? Nigh on impossible!
    StooMonster
  4. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    EvilMudge, not wishing to take off-topic but......
    Stoomonster,
    One way to remove Artex is to use a steamer, normally used to remove wallpaper - judicious use required, hold it in one place for too long and it will remove the underlying plaster off solid walls in big chunks !!
    Sean G.
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Thanks for the tip.
    I heard this before, and I have a large steamer that I use for wall-paper stripping, didn't do much to the Artex though (it is rather old). Steaming ceilings is nigh on impossible too IMHO; be it Artex, wall-paper, or lining paper.
    In the end I just skimmed over the top of the Artex with plaster. :smoke:
    However, there are many other walls and ceilings in my house that are covered with this evil muck; I'll give the steamer another try when I get round to doing those rooms.
    StooMonster
  6. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Definitely the best solution!!!
