Star Wars Trilogy (Extended U.S. Version) ????
Discussion in 'Star Wars Movies Forum' started by Ghidorah, Sep 19, 2004.
  1. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hello
    On the DVD Digital World website it says that the version they have is the :-
    Full U.S. Version, Over 26 Minutes Longer than the Region 2 U.K. Release
    http://www.dvdworldusa.com/shopexd.asp?id=24204
    Has any one heard of this one or is it the extras that are longer or just because of pal speed up over the three discs ? :confused:
    Ghidorah
  2. Jonny1973
    Jonny1973
    I have the region 1 boxset and I'm not aware of it being an extended cut. Yes, a few minor alterations have been done sine the special editions but the films should not be any longer.
    My guess is that you are right in saying that it might be the PAL speed up. Runtime of 626 minutes divided by 24 frames equals 26 minutes.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,654
    7
    167
    Birmingham, UK
    +10,540
    mmm does seem concievable that over the 4 discs it will be 26 minutes longer.
    However, by implying that the UK release is different in content they are misleading customers either incompetantly if they are unaware they are the same or unscrupulously if they are.
  4. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    The E-Mail I got from them said :- Full U.S. Version, Over 26 Minutes Longer than the Region 2 U.K. Release...Don't settle for less...
    But does not say why it is longer than the reg 2 version
    If it is no different than the region 2 I might try and get the limited box from MVC
  5. Jbev
    Jbev
    Aug 6, 2004
    140
    London
    +4
    Simple, PAL speed up ;)
  6. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    JBev's right - though I don't know the techy reason why PAL versions are "quicker"
    If you compare any NTSC with PAL, the NTSC always ahs a longer running time - weird!
  7. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
    Very true mate... and if memory serves me right they have said this before when advertising several other dvd titles (I also get their e-mails)
    Regards,
    Iain.
