Star Trek TNG which region?
Discussion in 'Movie Forum' started by Lex, Mar 30, 2002.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all,
    I know this has been discussed before, but I couldn't find the old thread so am starting a new one!
    Region 2 Project have done a comparison (sound and vision) between the regions 1 and 2 of the new Star Trek TNG box set.
    As one would have thought there is very little (no) difference between the two sound wise.
    And in their opinion the region 2 version just pips the US version in the vision department (but that is more of a personal preferance as there is hardly anything in it).
    http://www.r2-dvd.org/article.jsp?sectionId=3&articleId=3769
  2. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    Interesting that the R2 pipped R1 when used via composite, but that, aside from edge enhancement, R1 S-Video seemed more vibrant and perhaps better overall than R2 RGB.
    That would suggest to me that the lower quality exhibited via composite is as a result of this connection type masking a great deal of the quality of both regions, the final result of that being a picture who's quality is based solely on the technical diferences between PAL & NTSC (specifically line structure in this case).
    It would be interesting to see a test performed on seriously high end kit.
    I also find the lack of difference in audio quality interesting. As far as I can gather there is a 4% run-time difference so either all the episodes have been pitch corrected or a proper comparison has not yet been carried out.
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Gosh you are so knowledgable on the subject confucius! Personally I am just going by the packaging!! :rolleyes: :D
    My kit isn't really good enough (yet!) to show the differences anyway, so I am really concerned about which one looks best on the shelf!!
  4. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Thats why I got the R2 version it looks better. OK the picture quality may be slightly better on the R1 release but the R2 release is more of a collectors item.
