Star Trek Next Generation
Discussion in 'Movie Forum' started by mjn, Mar 6, 2002.
  1. mjn
    mjn
    May 24, 2001
    23,527
    Herts, England
    +11,930
    Was the decision of which region to buy decided?
    R1 or R2......
  2. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    Well, nothing in life is absolute.
    I'm going for R1 because I feel both NTSC and film sources are best served by NTSC format discs. A difference in packaging was mentioned but I feel this is an irrelevance.
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Confucius may have a good point about the NTSC quality.
    However, for me personally the packaging is far from irrelevant, especially if you are going to purchase all seven (which will take up a lot of space on the shelf). It is not just a slight difference: the region 2 version is much much better! In fact I have american friends who are importing the European versions.
    Also, I believe the region 2 version will be out before the region 1.
    Hope this is some help.
  4. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    Well, each to their own over the packaging :)
    R1 is due March 26, R2 was originally due before (March 25 ?) but is now due April 1. Either way the date diference is/was small. It looks as though both regions will be getting one season every 2 months.
    It also seems as though this is one case where R2 could well be cheaper than R1:eek:. The lowest I've seen the R1 version is from A&B sound at C$160.79 incl s&h, around £71 - and of course one could well get stung by HMC&E. Lowest I've seen R2 is £69.99 from Movietyme.
  5. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Was just on the DVD.co.uk site and I noticed that they are doing the region 2 version for £64.99.
  6. edd
    edd
    thanks for pointing that out, i think ill order from them :)
    65 seems very reasonable
    edd
  7. mjn
    mjn
    May 24, 2001
    23,527
    Herts, England
    +11,930
    think i'll get R2...as the packaging is just so cool!! and no chance of getting customs problems...
