Star Bargain CRT - Need Advice
Discussion in 'Projectors, Screens & Video Processors' started by meep, Apr 27, 2002.
Thread Status:
Not open for further replies.
  1. meep
    meep
    Apr 22, 2002
    782
    46
    Ireland
    +118
    Hi All,
    Looking around for a good cheap CRT, a vendor is offering me a VIDIKRON TGS550 for 250 euro (!)
    He says it's about 5 years old, that he sold it new to a client and has now taken it back in exchange.
    For this week it's on loan to a pub as he is repairing their PJ. I went along to have a look.
    The setup is terrible as i figure they just popped it onto the bracket with no set-up (as its a very short term loan). The picture is out of focus and pincushion is bad but the colours appear strong and it's very watchable at about 6' 4:3 in a lit pub lounge.
    The unit itself looks in very good order and, interestingly, it's got a SCART input. (Is this unusual?)
    One issue is a very thin black line running right down the centre of the picture.
    I figure for the price, it's worth getting if only to learn about CRT set-up (ie, i can afford to blow it up). However, a few questions;
    1. Does anyone know of a possible cause of the black verticle line?
    2. Does anyone know anything about this PJ, specs etc.?
    3. Anyone know where I could source set up or technical manuals?
    4. Anyone know the actual production history of this model (when etc.)?
    Many thanks in advance.
    Peter
  2. meep
    meep
    Apr 22, 2002
    782
    46
    Ireland
    +118
    Hmmm
    further research has revealed that this is a VIDEO grade PJ (which probably explains the SCART)
    So I suppose it'll be no good with a HTPC then. Anyone think it might look ok driven by svido out from Radeon 8500 ??
    Thanks again
    Peter
  3. Arthur.S
    Arthur.S
    as you say for 250 euro (about 190£?) you can't go wrong. If it's got a scart on the back, maybe it takes an RGB signal? Possibly the line up the middle will go anyway when fed with a different signal/source.
    If you connect it to the radeon using a s-v to scart cable, should work OK.
  4. meep
    meep
    Apr 22, 2002
    782
    46
    Ireland
    +118
    well, my othe roption is an ex-hire Barco 801 (don't know yet exact spec, s or not etc).
    The guy is looking 2000 euro and says it's a take it as is, no set up etc.
    This sounds a bit much to me given that the forum seems to say £1,000 stg for a good condition 801.
    Then again, that will give me higher quality inputs......
    The though process goes on and on.....
  5. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,208
    3
    +8,305
    That is way to expensive for an 801, you should find a very good example for no more than a grand. And a usable machine for around £500-900
  6. Arthur.S
    Arthur.S
    THX, I've just had a blimp at your HC pics, dunno why I haven't done it before:rolleyes: Really nice setup mate. Interesting that the first pic which shows your 'significant other' (I presume that's who Sarah is) is entitled "The pain...":D :eek:
Thread Status:
