Stands for Quad L-ites
Discussion in 'Home Cinema Speakers' started by AndyMoody, Jan 17, 2008.
  1. AndyMoody
    AndyMoody
    Dec 23, 2003
    307
    Bucks
    +19
    I'm looking at getting a Quad L-ite setup but need to mount the rear speakers on some stands that I can somehow attach the speaker to that will not come off and hit the deck if the dog or kids give it a bash. Any ideas?
    I understand the Quads have 3 holes on the back if you want to use wall brackets which I can't.
    Someone must have come up with the same sort of issue.:lease:
    Andy
  2. Cynar
    Cynar
    Mar 4, 2007
    2,289
    Lancs
    +238
    I tried to find something similar a while back without success.
    The only stand mounts I could find with any sort of fixing for the rear were flimsy satellite stands like they sell in Argos.
    I eventually got some big square double sided sticky foam pads from a DIY store and used them between the base of the speakers and the top plate of the floor stands.
    Worked a treat. Wasn't so easy to remove when I came to sell the speakers though!
  3. AndyMoody
    AndyMoody
    Dec 23, 2003
    307
    Bucks
    +19
    I guess they were something like the sticky pad things that Halfords sell for attaching car numberplates? I know they come in 2 different thicknesses and stick like something to a blanket..................
    Cheers,
    Andy.:thumbsup:
