Standmounts to match Arcam?
Discussion in 'Arcam Owners' Forum' started by tamthetim, Dec 15, 2004.
Tags:
  1. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    I have recently separated my AV setup and bought a second hand A85 amp to run my CD73T player. I also bought a second hand pair of Mission 780's from a mate but don't feel they do the system justice.
    Any recommendations what speakers match the system and what doesn't.
    Cheers, Tam
  2. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Leema Xens with good stands wonderful I use 3 for my fronts, about A5 size such bass from a small box. Supplier in Scotland.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    How much are you willing to spend?
  4. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I recommend you demo a pair of Dynaudio 52SE with a good set of stands (like the Dynaudio Stand2). These speakers are very neutral, detailed, and revealing. A good match for Arcam gear. They like power, but the A85 should do them justice unless you're in a large room. I use Dyns powered with Alpha 10 and 9 amps.
    Short of going to the Contour or Audience series, the Dynaudio 52SE are the most impressive bookshelves I've heard. An excellent value for the money.
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    The Monitor Audio Gold 10s work really well with the Arcam kit too.
  6. malcolm mccabe
    malcolm mccabe
    Also it will depend on what type of music you listen to, as you'll hear lots of times, the best way is to demo a few with your own music.
  7. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    A lot of people make this statement, and I've completely disagree with it. If a speaker is truely good, it should be music style neutral.
    To say that some speaker sounds good with this but not that tells me the speaker itself artifically colors the sound in some way. I want a speaker that reproduces source accurately without adding or subtracting anything (the ideal).
    That's what I've always loved about my Linn Saras and Dynaudios. They sound great no matter what I throw at them. If I auditioned a speaker that sounded great on Classical and other acoustic music, but then fell apart with pop or other electronic music, I'd reject it in a heartbeat.
    If a speaker sounds good in some circumstances and not in others, then it has obvious shortcomings.
  8. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Agreed, a good speaker will play all kinds of music + AV... :lesson:
    Wich doesnt exclude that some speakers will play fairly well some kinds of music but be lousy with other types, those are bad speakers... :rolleyes:
  9. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    Thanks for the advice guys..............was looking to spend between £400-£600 if poss..............will audition some of the speakers mentioned..................my room is about 4.2 x 4.5 metres.
    I use to be mainly a rock fan.................but the better quality system seems to be opening up my taste a bit.....playing joss stone........the doors..........some stevie wonder at the moment.
    Any view on the Quad 12's they seem to get great write ups?
    Cheers, Tam
  10. Commited
    Commited
    Check out the B&W 602 S3's and 705's - both beautiful speakers :)
  11. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Great write-ups only mean they pay a lot of advertising... ;)
    And me, or anyone else, recomending a certain brand, doesnt mean much either, unless you hear my system and know my tastes...
    Go and listen to some speakers, I´d say avoid speakers with a lot of bass, like the B&W 602, they will boom in your almost square room, better smaller speakers + subwoofer...
