Standby not working
Discussion in 'Microsoft Windows' started by DaveP, Aug 29, 2005.
  1. DaveP
    DaveP
    I'm embarrased to ask this but can anyone suggest what the problem is?
    Up until now I have been running one MC PC 24/7 and the other I have either switched off or put into hibernation.
    I've now decided that I really need to go to standby, wake to record and return to standby. When I select standby the PC goes through the motions and the screen blanks and then, with no delay whatsoever, it wakes up again.
    Have I missed something in the Bios settings or is it something in Control Panel? Or something else?
    Dave
  2. markav
    markav
    Jul 19, 2005
    96
    Suggest you try disconnecting devices such as mouse, keyboard, network cable to identify which one, if any, is causing the wake-up.
  3. DaveP
    DaveP
    Thanks for the suggestions. I'm not sure what the problem was but it works OK now.
    When I say OK, I mean sort of OK!
    Now when it comes out of standby the mouse works but the keyboard doesn't. They are both wireless Creative devices using the same IR USB receiver so I'm at a loss to understand how one works and the other doesn't!
    Dave
  4. markav
    markav
    Jul 19, 2005
    96
    Most strange!
    I have noticed that when coming out of standby, I need to let the PC settle down for 10-20 seconds or my remote control doesn't work (even if it was used to wake up).
