Standard Sky+ Installation - replace LNB?
Discussion in 'Sky Digital TV Forum' started by Borrower, Jan 2, 2005.
  1. Borrower
    Borrower
    Hi all,
    I am getting Sky+ installed on 15th Jan which I am hoping will cure a problem I have with my current Satellite Receiver (Panasonic) :-
    I get the 'No signal received' error only on some channels (mostly BBC and ITV).
    I read in another thread that this might be a faulty LNB so I am now wondering if they install a new LNB when the install Sky+??
    Or if they dont as standard are they likely to replace it (free) if its still a problem after Sky+ install??
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    AFAIK, you should get a quad LNB installed to replace the current, dual, one.
    John
  3. Borrower
    Borrower
    Thanks John,
    Presumably thats for future expansion? I'm assuming that Sky+ only needs two feeds and therefore the standard dual LNB would be adequate?
  4. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    A dual LNB would be enough for Sky+, the quad allows you to have one or more boxes in other rooms.
    John
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    SKY stopped using Dual units for two reasons, the first was compatability problems with certain units and the second was simple economics, they order a hugh number of Quads and the cost per unit was cheaper than buying a smaller amount of Duals.
    Depnding upon the cost differences between Dual and Quad to fit your dish it may be prudent to spend a little more with future proofing in mind.
