Standard HDMI Cable works on 3D??
Discussion in 'Cables & Switches' started by alasone, Jan 9, 2012.
  1. alasone
    alasone
    Mar 20, 2008
    967
    2
    +62
    Hi guys,
    Just treated us all to a brand new 3D TV. LG Passive 54 series something or other.....
    The 15m cable I bought 2 years ago I presume is 1.3???
    Anyway, just went on eBay and purchased a standard cheap 1.4 at 15m.
    But just put the TV on the wall and plugged the installed cable from 2 years ago in. 3D Works perfectly????
    Any help as to why??
  2. alasone
    alasone
    Mar 20, 2008
    967
    2
    +62
    I should say the source is SKY 3D.
    Not tried the BD Player yet....
    This has baffled me.
  3. Member 319784
    Member 319784
    Previously HDC James
    Nov 3, 2008
    1,502
    Malvern
    +240
    Sky 3D is not as high a data bandwidth as Blu-ray 3D content.
    You dont need a special or new (mis-labelled) '1.4' cable for 3D. Just a High Speed cable.
    Many '1.3' cables offer high speed performance anyway.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,164
    The Borders
    +3,376
    There is no ‘special’ internal re-wiring of the HDMI cable required for 3D – it’s simply down to the bandwidth your cable can pass.
    With a decent gauge 15m cable you can achieve 3D without any special electronics – though you can’t guarantee it.
    HDMI.org advise you to use a High Speed cable for 3D – though it’s not mandatory and they also then make it impossible for anything over 8m to pass the High Speed test unless its amplified!
    HDMI :: Manufacturer :: HDMI 1.4 :: 3D
    Hopefully you’ll be OK with 3D from the BD Player too!
    Joe
  5. alasone
    alasone
    Mar 20, 2008
    967
    2
    +62
    Thanks chaps. Hope it works with the BD player too. Although wasted money on a new cable by the looks of it..!
  6. freddie5
    freddie5
    Dec 21, 2006
    744
    +271
    I have just ordered a Panasonic 42GT30 and blu-ray bundle, and i have been reading about the need for high speed HDMI cables.
    I was lucky enough to purchase some of those incorrectly packaged QED ones, Classic box - Performance cable??, from Tesco recently, so my question is this - are they good enough to support 3D??
    Thanks.
  7. Member 319784
    Member 319784
    Nov 3, 2008
    1,502
    Malvern
    +240
    If they are under 5m then yes probably
  8. freddie5
    freddie5
    Dec 21, 2006
    744
    +271
    Yep, 1 metre.
  9. Member 319784
    Member 319784
    Nov 3, 2008
    1,502
    Malvern
    +240
    Very good chance that it will then.
  10. andy1249
    andy1249
    May 7, 2006
    8,452
    +2,543
    3d Blu-ray is 2x1080px24fps. Multiply this out and you will see that it is less bandwidth than a 2D 1080p signal at 60fps.
    So , is there any kind of special HDMI cable needed for 3 D? No there is not.
    All long cables may have problems due to the inherent attenuation problem, but this is not specifically a 3 D issue.
    Short cables are likely to pass any signal you can throw at them ,regardless of what rating it has.
  11. skyjuice
    skyjuice
    Nov 2, 2011
    92
    11
    london
