Standard Definition TV and component PC output
Discussion in 'Desktop & Laptop Computers Forum' started by benmiles, Mar 6, 2005.
  1. benmiles
    benmiles
    Feb 9, 2005
    47
    Hey guys,
    I have a Toshiba 36" picture frame CRT and have been running a HTPC happily over S-Video for some time. However, I just bought a new graphics card which supports component output (ATi X800 Pro). Thus far, whilst I have been able to get output over component, it is only working at 640 x 480. If I go back to s-video, 1024x768 is possible, but the readability of text is poor.
    What I want to do is output at 1024 x 768 via component to improve quality. I have tried every setting in the Catalyst control centre - and had a dabble with power strip to no avail. I even tried to duplicate the exact powerstrip settings that work on s-video using component to no avail. Am I just barking up the wrong tree or is there a solution?
    Any help would be appreciated!
  2. stlic
    stlic
    Feb 17, 2004
    744
    +15
    Does the Tosh actually support any res through component other than 480p? I would think you would be limited at that. Also the 1024x768 through s-video, I believe, is actually downscaled to standard PAL resolution before being outputted so you don't actually gain any additional definition although you get more visible desktop with the text limitation you have noticed.
    If you don't get any movement with different component resoltuions (havn't had the opportunity to try it myself) the VGA-->Scart RGB option would suit you well and allow you to have a true widescreen resolution albeit not progressive..:(
  3. Thermopyl
    Thermopyl
    I too have a 36zp48 but can not get either the svideo or dvi-component connection to work (i am using the ati dongle). Did you sort your's out?
  4. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    I have had simlar problems with my Panasonic CRT 36PL32. I'm using the ATI dongle and have only ever managed to get a 480p desktop despite Pansonic telling me the TV will accept 780p via component. I've tried every combination of dipswitches and powerstrip settings you can think of but I think Panasonic are wrong and I'm going to give up.
    What I'm curious of though is what advantage there would be for me to actually achieve 720p as I've only ever connected via component, I haven't tried via scart or s-video so I can't make a comparison. Would connecting by one of those methods and successfully getting 720i or 1080i actually be a better option than 480p? Would the only advantage be playing HD content at 720p and a bigger desktop for browsing and for displaying more onscreen in the MCE frontend?
  5. Skunkpipe
    Skunkpipe
    If you don't have the correct refresh rate then you'll have problems getting it to work also.
  6. CodeThief
    CodeThief
    May 25, 2002
    660
    UK
    +5
    I have the 32ZP38 and I'm running 856x480p via the dongle + component. I have got 1024x576p working but I can't play any videos, it crashes the pc. Anyhow, your TV will support 576p. Good luck getting it working :(
    Dave
  7. 9761
    9761
    May 16, 2005
    499
    I have a toshiba 32zp48 TV and have all sorts of problems with the resolution.
