Standard Def Telly advice
dankell
Right,
managed to get my Wii today (Thank you Game, Camden) :thumbsup:
One quick question that I've not managed to untangle from the various Compnent/RGB/Scart threads.
I have a standard CRT 32" Widescreen telly.
It has Scart and Composite inputs.
The Wii comes with an adapter to Scart from Composite.
Will I get any advantage from getting an RGB Scart cable, or will I just get the best with the Scart adapter?
Lin3ar
The scart connector doesn't give you full RGB scart.It is still a composite feed.You will be better off with a proper RGB scart cable (if you can find one)
