stand by
Discussion in 'Desktop & Laptop Computers Forum' started by rab4169, Jul 25, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    i am about to build a htpc using mobile xp chip.
    when i set my computer to record from the tv on the computer does it go into stand by like a video and wake up to record, just wondering if i go on holiday do i need to leave my pc on all the time burning at full power.
  2. rab4169
    rab4169
    Dec 12, 2004
    533
    any update on how i put computer into standby while on holiday to record shows
  3. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Assuming that you're using MCE, then you must go into stand by from MCE and not winXP.
    Then when you come back Microsoft may have done one or most of the following:
    1. Remained on standby :eek: ;
    2. Woken, crashed & not rebooted :( ;
    3. Woken and rebooted, but not into MCE :mad: ;
    4. Woken into MCE successfully, but not recorded :suicide: ;
    5. Woken into MCE & recorded (but corrupted - not replayable) :confused: ;
    and it can even wake, record and and go back to stand by all by itself :cool: .
    I only say this, because that is my experience. Others of course may have had more or less luck :rolleyes: .
