Stampede or Strata V...........help please
Discussion in 'Subwoofers' started by funboy3, Mar 21, 2005.
  1. funboy3
    funboy3
    I intend to use the sub with both HT and stereo (Naim CDS II, 52 & Supercap, 135's and Sonus Faber Electra Amator II's).
    Is the Strata V erally worth the extra or is it just a question of room size?
    Thanks in advance
  2. Resonance
    Resonance
    Jan 31, 2005
    268
    +17
    I read a HiFi Choice review of these two subs. Their focus was on music and their conclusion that the Strata V was slightly better than the Stampede, but did not justify the extra cost. They noted that the intenal size of the Strata was not a big as the outside would suggest as there was an internal partition. They also said the law of physics came in when used for LFE - meaning don't use them in large rooms of for very high volumes.
    Their rating was they were both 4 stars out of five for sound quality and value.
    Having said that, as we are all different, with a different sense of what consistutes 'good value' only you can really answer the 'worth the extra' question. ;)
    Ian.
  3. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    I have had a stampede for a little under a year now and can say that I am very happy with it. Both music and movies give a clear and crisp note.
    I cant comment on the strata 5, but if its up to the usual Rel standards you wont be upset.
    The only other option might be to look at the Velodyne subs.
    Fish
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    That wouldn't be the first option in most people's minds let alone the only option when looking for a subwoofer in that price range for a high quality music system.
    Much more appropriate alternatives would be available from MJ Acoustics and Quad
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I would get the Storm V, or look for an used Strata III, both have proper size boxes... :smashin:
  6. gktk
    gktk
    Aug 26, 2003
    100
    16
    i recently purchased a strata 5 2nd hand, very impressed and handles music and movies very well
