Hey all,
I moved house on Tuesday and had a pair of Sky engineers arrive wednesday afternoon to attach a new lmb to the existing dish and run cables to the lving room (through a wall in the garage) and to drill a hole into the master bedroom.
Apparently the can't drill through tiles which meant they couldn't install the bedroom. Then they said they couldn't just do the living room because it would change the description of the job.
So they recommended I call out an independent company to do the installation.
I the meantime I hooked up my sky plus box to the existing cable in the living room which interestingly allows me to pause and record anything I'm watching but obviously I can't record anything I'm not watching because there is only 1 feed.
The installers said I could get a "stacker" which would split the single feed into the equivalent of two cables... Has anyone tried this? Can someone recommend a particular component to use?
