Stacked Runco1200's...(Barco Cine9'S to you and me)
Discussion in 'Projectors, Screens & Video Processors' started by Gordon @ Convergent AV, Feb 27, 2003.
  1. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    They are definitely over-compensating for something! :p
    Seriously though, isnt that overkill for 10 foot?
    ad
  3. X3ELS
    X3ELS
    May 20, 2002
    1,144
    Surrey
    +108
    At a talk given by Sam Runco in Vegas this January (me and Gordon were there) he stated that a 9 inch CRT will be running at its optimum on a screen size of no greater than 7ft.
    So 2 x 9inch driving a 10ft screen would probably be ok, if not still a bit too big.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    This is rear projection so the formulas change a little. It would probably hurt your eyes on bright images.
    The PJ stand looks like it was made up from an old packing crate.
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
    I think it sounds like a nice system...
    "The PR-650 measured light output from the stack as approximately 7.75 footlamberts. Doesn't sound like a huge amount of light, but dynamic range is spectacular."
    Gordon
  6. uncle eric
    uncle eric
    Sam Runco openly admited once that he used to take the mick out of Joe Kane for suggesting 7ft is the max for any CRT including 9 inchers. Seems like he's come around big time.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    I'm with Roland
    Wonder why they used old pallets for the projector rig - a decent rig would surely have given the installer a bit of a help and made any servicing so much easier.
    Wouldn't mind that set up at home though - beats my pull up floor screen and whatever projector I happen to have around on the day!
    Best regards
    Joe
  8. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,430
    London
    +280
    So that we never loose this info I have copied the full write up into this thread..........
    For the past few months Films on Disc has undertaken a huge reference home theater revamp. In an effort to deliver the most accurate appraisals of DVD quality, new twin CRTs have been stacked in a rear configuration. Two CRT projectors were used in order to light up a ten foot wide 16 x 9 screen without overdriving the projectors and thereby diminishing image quality. With all the new associated equipment, a new black hole theater environment, we hope that our critical evaluations will enable us to present the most accurate DVD reviews possible.
    We take our reviews seriously. If a DVD looks good on our very revealing system, it will look good on smaller less revealing systems as well. Many readers make their purchases based on reviews. DVDs evaluated on less revealing equipment may fail to detect the nuances that make or break DVD quality. The flip side of the evaluation coin is that inferior equipment can mean a DVD is not being displayed to its full potential and equipment may introduce artifacts not inherent to the source DVD. Does the DVD player present the sharpest image possible from the software? Is full color bandwidth realized by the equipment?
    NTSC artifacts are often hidden when resolution is pinched on a display device. Improper equipment set-up can introduce its own set of problems. Pushed contrast levels can bloom image causing a loss of detail. A careless turn of the sharpness control can introduce excess noise or exacerbate edges causing ringing. Calibrated equipment is an important part of getting the image from your system. Is the monitor capable of showing everything, warts and all, contained on the software? Does the logic steering in your surround processing accurately place sound throughout the theater. Do acoustic anomalies in the theater create their own problems? All these aspects of controlling the equipment and environment impact on an evaluation.
    The Films on Disc reference home theater does feature some of the finest equipment available, but in an effort to maximize performance, crack ISF set-up man Jim Doolittle inspired and consulted on the theater from the get-go. It all started when Jim was on a visit to the last incarnation of the theater and I went into a room behind the theater to retrieve a piece of equipment. Jim's eyes lit up! Rear screen stack was flashing like a set of road markers. That was the beginning of the new theater. Once the equipment arrived and the theater environment was made image and sound friendly, Jim arrived (from Boston) to set-up and calibrate the stack of Runco 1200 9 inch CRT projectors. Anal in, anal out, so they say. The time you put into careful set-up will yield pristine pictures, and such is the case in our theater. An optical comparator was used to set gray scales and ISF tech Ken Whitcomb (from Indianapolis) stopped by with his Photo Research PR-650 color analyzer to check settings against the comparator and make some very minor adjustments. The PR-650 measured light output from the stack as approximately 7.75 footlamberts. Doesn't sound like a huge amount of light, but dynamic range is spectacular.
    Setting up a vertical stack of projectors to yield the best image took some thought and determination. A stand was built accommodate both projectors. One was set-up as ceiling mount and one as a floor mount thereby situating the CRTs in an opposing configuration to create extraordinary white field uniformity. Each projector is set up step by step on its own and then the slave projector is converged to the master. A vertical stack is definitely a lot easier to converge than a horizontal stack as previous experience taught. Happily, the 1200s seem to be very stable beasts, satisfied with keeping their convergence in one place. The convergence process must be duplicated for multiple memories in the projectors, but the process is far less arduous than the initial set-up. In our case, set-ups for base 6500K, 1080I HDTV, and 5400K for black and white were set-up. Aspect ratio control is done through the Runco 4404 Ultra video processor.
    It's important to remember that having reference quality equipment may not be enough. Set-up and maintenance must be first-rate. How many times have you seen a home theater demonstration displaying poor images? Too many times is the answer. Great equipment can only create beautiful images when it is properly set-up. Top rank calibrated monitors can accurately replicate colors as intended. A calibration by a qualified technician is invariably necessary. Even the best equipment doesn't perform perfectly out of the box. With home theater projectors, slight convergence errors can make an image appear softer. More contrast than your equipment can handle can make a picture look soft or even distort the geometry. Too much brightness can make a picture look washed out. Has the surround sound been properly balanced? It's the only way to know if a disc has been mastered properly. The answer is great weight must be given to finding the right set-up people.
    It's crucial in making a fair evaluation that display and audio equipment have the ability to replicate what is on the software. Sometimes you can fiddle with a picture to make it look better, but who wants to get adjust the picture and sound every time you watch a different movie. A standard is of utmost importance. DVDs and laser discs should be mastered to a universal standard. Colors should be presented for mastered for 6500 degrees Kelvin viewing and equipment should be calibrated to decode this accurately. You should be confident that if your equipment is properly calibrated a well mastered DVD will look great. And so it falls upon the reviewer to hold to even more stringent standards. Reference equipment and diligent maintenance are the answer.
    Films on Disc does attempt to maintain the highest standards in its home theater equipment. Projectors are calibrated ISF trained personnel. Projector convergence is constantly monitored and disc anomalies are checked against possible set-up errors.
    DVDs are evaluated on the following current home theater equipment:
    Rear configured Stewart 67 1/2' x 120" Aeroview 1.0 Gain Ultimate 4-Way ScreenWall , 2 Runco 1200 9 inch CRT Projectors stacked floor and ceiling configuration, Runco 4404 Ultra Digital Video Processor, Faroudja DVP3000 Digital Video Processor, Lexicon MC12 Surround Processor/Switcher, Sony 7700 DVD Player, Sony 7000 DVD Player, Panasonic RP-91 DVD Player Sony 9000 DVD Player, Pioneer Elite CLD-97 Laser Disc Players with AC-3 Modification, Revel 7 channel speakers configured with 2 Gems Front, 1 Voice center, 2 Embrace sides, 2 Embrace rear, 2 Bag End Infrasubs, Lexicon 7 channel Amp, Lexicon T-700 System Remote Control with TCM-3 RF interface Speaker Wire and Interconnects by Monster.
  9. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,430
    London
    +280
    On the Rack
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]Runco 4404 Ultra Digital Video Processor[​IMG]
    [​IMG]
    Monster M-Series Interconnects​
    The Screen
    [​IMG]
    Stewart Ultimate 4-Way ScreenWall with Aeroview Screen
    Behind the Screen
    [​IMG]
    Two Runco 1200 9 inch CRT Projectors
    [​IMG]
    Trimmings, Decor & More
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Revel Speakers, 2 Gem, 1 Voice, 4 Embrace.
    [​IMG]
    Monster Speaker Wire
    [​IMG]
    Acoustical wall and ceiling panels from Acoustic Innovations
