st429966/af stand
Discussion in 'LCD & LED LCD TVs' started by killer10971, Jan 14, 2005.
  1. killer10971
    killer10971
    Dec 29, 2004
    1,021
    +29
    can anyone confirm that the phillips st429966/af stand fits the 37inch screen (37pf9986)
    all the pics of this screen on the net it says that this is the stand to use
    i bought one from john lewis and it says on the box 42inch and above
    many thanks all
  2. Ricardfred
    Ricardfred
    Feb 5, 2004
    83
    Hi. I just took delivery in the past few minutes of the Philips 37PF9986 and the floor stand you mentioned. I wont be unpacking them until tomorrow after I get rid of my hulking 32" Sony widescreen so can let you know then. I was told in the shop that this floor stand fits all 3 screen sizes, but the shelves should be about 1cm less than the 37"screen. Seemingly the screen is raised off the sheves on a pedistal and you can rotate it. Cant wait!!
    Update:Just noted my box says stand is ST009966, so may not be the same.
  3. inventor
    inventor
    Nov 29, 2004
    33
    That is the right stand. I got mine and the 37pf9986 last week. You have to assemble the stand yourself but its pretty easy.
  4. killer10971
    killer10971
    Dec 29, 2004
    1,021
    +29
    many thanks all
    just putting the stand together and have noticed two large scratches on the glass and the silver spray job on the metal looks like it was done by a chimp
    £200 what a bargain , back it goes
    but thanks to all who replied
