SSD MacBook Upgrade - do it
Discussion in 'Desktop & Laptop Computers Forum' started by kevin1982, Sep 2, 2017.
  1. kevin1982
    kevin1982
    Jul 3, 2016
    151
    Tyne & Wear
    +14
    If you have a MacBook which allows you to change from a regular 2.5" hard drive to SSD - DO IT
    I was regularly getting the beach ball without much work being done so made the decision the HD was getting a bit tired. I timed a startup at 2mins45 before the swap to a Samsung 850Evo SSD, now it's 25 seconds and instance program load
    Don't rush out and buy a new MacBook, save a fortune and upgrade to SSD and max the RAM
