SSD in Sky Box
Discussion in 'Sky Digital TV Forum' started by RedSea, Jul 7, 2015.
  1. RedSea
    RedSea
    Jun 23, 2010
    27
    Winchester, Hampshire
    Given how much the cost of SSD's have come down in recent years does anyone know a retailer that sells new Sky boxes with an SSD fitted, I'd like one due to the increased speed, reduced noise and reliability. Even sat 5 metres away form my Sky box I can still hear the SATA hard drive sometimes
  2. logiciel
    logiciel
    Feb 2, 2008
    53,163
    UK
    +5,789
    A Sky machine should be silent, and no-one invalidates the guarantee AFAIK.
    If you're a subscriber and don't have the current machine I recommend getting one free.
  3. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Not sure how it would speed anything up, boot time maybe. The cost of an SSD is still roughly double the cost of a standard SATA drive
  4. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
    There won't be much, if any, speed increase as the OS doesn't run from disk. They are not designed for SSDs so wouldn't support TRIM and would get slower over time.
    No spinning drive is silent but some are better than others. Swapping the drive is an easy DIY job.
  5. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,224
    Poole
    +11,856
    It is important to remember the live pause buffer is running continuously, I don't know how this will affect the SSD.
  6. AsinineMonkey
    AsinineMonkey
    Sep 21, 2005
    28
    3
    London
    +3
    Neither should be a concern with modern SSDs that handle GC properly. The false belief that "it must support TRIM" for an SSD to be of benefit really needs to disappear:
    http://www.thessdreview.com/daily-n...ion-and-trim-in-ssds-explained-an-ssd-primer/
