Ssd & Hdd
Discussion in 'Computer Components' started by FDM, Jan 11, 2012.
  1. FDM
    FDM
    Dec 30, 2011
    Have my Ssd hooked up and installed windows on to my new system now looking to install my normal HDD not sure what to do tho as just plugging it in won't pick it up.
    How do I install it as a secondary/slave drive?
  2. bigtruck
    bigtruck
    Apr 29, 2009
    6,048
    163
    Liverpool
    +2,130
    I just plugged both of mine back in and they worked fine mate, not sure why it wouldn't; assume you've checked the connections?
  3. FDM
    FDM
    Dec 30, 2011
    There both plugged in properly, I read I should just plug the second in after windows install and it should pick it up, but it hasn't :/
  4. bigtruck
    bigtruck
    Apr 29, 2009
    6,048
    163
    Liverpool
    +2,130
    Strange, that's what I did & it was fine:confused:
    Is it showing in the bios?
  5. FDM
    FDM
    Dec 30, 2011
    Not looked mate, will have a look tomorrow afternoon and check back. Out for the night then off to work.
  6. betelgeus
    betelgeus
    Jun 7, 2005
    377
    +16
    i presume you hdd has data on it and may have been used with other hdd in a dmi pool,even if it shows up in bios it might not show up in windows.
    try this
    start>right click computer>manage>disk managment
    the hdd might show up here and you may need to reactivate(or import or even assign a new letter) but read any warnings fully i don't want you reformatting it by mistake.
  7. FDM
    FDM
    Dec 30, 2011
    No mate it's a brand new build, everything is out the packet. Will try that when I get home tonight so there won't be anything on it.
  8. FDM
    FDM
    Dec 30, 2011
    Cheers, you are a legend!!!
