GloopyJon
I have an OCZ Vertex 2 120GB SSD which is my C: drive and contains Windows, most of my applications and some data (I put the bulky stuff onto hard disks). About a week ago, things started going wrong. First of all, Microsoft Money stopped loading. A day or two later, the other Office applications stopped loading. Then it started getting temperamental about booting up, and finally it stopped booting altogether. Now when I boot up, the drive is recognised in the BIOS but it says there is no operating system.
When I boot from my Windows 7 installation disk, it does not identify the drive - I try to do a Repair but it doesn't show the disk (or any other) in the list of installed partitions (the lack of any others is probably OK since they don't have Windows installations on them).
I took the SSD out and connected it to my laptop via a USB adapter (something like this), and it seemed to be fine. I copied my entire Users folder to my laptop, which took ages but seems to have worked alright (all of the files I have opened to test it have been fine).
At the moment, I'm a bit stuck since I can't do anything with it in my PC. My next planned step is to flash the firmware, for which I will try to connect it to another PC as a secondary drive. Not sure if that will help, though.
Does anybody have any ideas or suggestions? All help gratefully received!
