SS makes double copies when importing a moved track
Discussion in 'Headphones, Earphones & Portable Music' started by NoviKaNa, Sep 4, 2005.
  1. NoviKaNa
    NoviKaNa
    Jul 17, 2005
    Hi!
    Anyone got a solution to my problem? If I move an imported file to another folder and later on scan that folder for new files, SS import the already imported files again, making double copies. Annoying!
    I'm sure the only solution is not moving imported files, but maybe someone got any tip?
  2. shadowritten
    shadowritten
    You can manually deselect folders so that SS doesn't look in them. Annoying, but effective. Check out the program's Help file ...
