SS 3.x solution for multiple artists albums!
Discussion in 'Headphones, Earphones & Portable Music' started by moscho9999, Apr 26, 2005.
  1. moscho9999
    moscho9999
    :thumbsup:
    I would like to share a post I found on a diffrent forum regarding SS creating lots of separate albums with the same name and every album containing only one track (e.g. compilation albums).
    A user called MDfreak found the following solution that worked out fine for me:
    ISO setting the "compilation"-option for each single file
    - Go to the "all tracks" view in SonicStage
    - Select all tracks and choose "properties" by right clicking on one of them.
    - Wait some time for the properties to appear.
    - Set the option "tracks in the compilation albums"
    - click ok and wait some time (in my case about a 2 minutes) for SonicStage updating the properties of all albums.
    Now all the tracks of one album are in the same SonicStage-album despite that some tracks in the same album have different artists.
    Hope the hint helps
    Moscho
  2. chromosome
    chromosome
    Apr 7, 2005
    1,323
    48
    Midlands
    +47
    thanks for the info!
  3. marooned
    marooned
    what exactly does this allow you to do
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    I did this as well, except I only did it for compilation albums.
    I went to "All Tracks" and typed in the album names for the various compilation albums in my library. Then, as moscho says, I right clicked - properties and selected the tick box.
    This sorts out the problem of having all your compilation albums split up in SS, into 20 or so one track albums. SS does this because it list the albums by artist, so unless you tell it that they are compilation albums they get separated.
  5. scottydog
    scottydog
    Mar 22, 2005
    55
    This didn't altogether work for me though I may be misunderstanding what was meant. SonicStage on my PC didn't show each track separately but the HD3 does. Changing the properties to 'compilation' didn't have any affect. I also had to change the name of each artist too. Changing each artist to the name of the compilation album or just 'various artists' did the trick. This obviously means you loose individual artist names but I can live with that. I also had to delete the old versions from the HD3 and transfer them again with the new properties. Changing the properties only took seconds too. There was no waiting at any stage.
