SS 3.1 for HD3?
Discussion in 'Headphones, Earphones & Portable Music' started by meddyliol, Jun 4, 2005.
  1. meddyliol
    meddyliol
    May 11, 2005
    45
    :clap:
    Does anyone know if the SonicStage 3.1 software will work with the HD3? I would assume that it does but one never knows does one.
    Is the HD3 as good as they say? I am returning my HD5 because of crack problems.
    :devil:
  2. Inter
    Inter
    Feb 15, 2005
    SS 3.1 works with the HD3
    I got a HD3 and I'm completely satisfied.
  3. watchinthewheel
    watchinthewheel
    hell yes, if you can get past ss its awsome!
  4. tottycs
    tottycs
    if you dont like SS (as all of us dosent do) you shoud try downloading "VAIO music transfer". that is a program who you just "drag and drop" :D god luck :p
  5. sbradnam
    sbradnam
    Feb 13, 2005
    32
    North Yorkshire
    3.1 is much better - less prone to crashes, and a bit more user-friendly. Still room for improvement - NB SONY!!! - but it is better than 2.3. Remember, the SS software is essentially resident on your PC, not your HD3. Oh, and my HD3 is excellent.
    Go for it! :thumbsup:
  6. briankai
    briankai
    I would try to use the Vaio tool instead... I don't know what special version of SonicStage some of these guys have, but mine (which is allegedly the latest version) can barely display the library without crashing.
    Kai
  7. JJ VDUB
    JJ VDUB
    Vaio music transfer. Will this allow you to load CDs and transfer to your HD3 without using sonic stage at all? (I know you still need SS installed for the various components).. what version of SS do you need?
  8. Fanboy
    Fanboy
    Feb 16, 2005
    25
    I have a HD3 and am running SS 2.3, which crashes often.
    I recently got an email from Sony offering me an upgrade to SS3.1 but didn't list the HD3 in the list of hardware it would run with, which scared me off. Can anyone confirm:
    1. NW-HD3 works with SS 3.1
    2. Can I 'upgrade' 2.3 to 3.1 without having to load my music library again.
    3. Can I upgrade to 3.1 without having to initialise my HD3 and thus load all my music back onto it.
  9. CSB-260
    CSB-260
    Loading the library on 3.1 is so much better anyway
  10. loser
    loser
    Jun 3, 2005
    36
    As everyone says, Vaio music transfer is sooo much easier. definitely more than halfed the time to put on all my songs
  11. Fanboy
    Fanboy
    Feb 16, 2005
    25
    So with this VAIO music transfer, can I ditch Sonic Stage and use this instead? How does it work/where do i get it?
    Still want to know pros/cons of upgrading to SS3.1 with a NW-HD3
  12. CSB-260
    CSB-260
    Trouble is with VAIO Music Transfer is, as far as I can see, only available with a VAIO product, unless there's a site I haven't found
  13. dowlinmp
    dowlinmp
  14. emqav
    emqav
    May 29, 2005
    32
    SonicStage 3.1 is compatible with ALL nw-hd models as well as with ALL other network walkman's from Sony and also with the Vaio Pocket Player !
    I'm using my NW-HD3 with SonicStage 3.1 and it works just great.
  15. Fanboy
    Fanboy
    Feb 16, 2005
    25
    Marvellous - thanks emqav!
    Got it! Cheers! :smashin: So should I keep SonicStage even if I install this VAIO software?
  16. tomiwolf
    tomiwolf
    well i updated ss 2.3 to 3.1 and after the update it takes some time - about 15 minutes - till ss recognizes the player. anyone got the same problem?
  17. Fanboy
    Fanboy
    Feb 16, 2005
    25
    Installed SS3.1 last night. No problems. Plugged in HD3 and SS picked it up straight away.
