SRC-2010 at Maplin, half price but is it worth it?
Discussion in 'Home Cinema Control & Remote Controls' started by DaveP, Sep 8, 2003.
  1. DaveP
    DaveP
    Has anyone, apart from Sick Boy, got one of these? Are they any good? Will they operate my Tivo and Panasonic HS2?
    DaveP
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Don't know about that remote, I bought the E Pilot one instead £29.99. It is now programmed to do my sky,vcr, av amp, cd, tv, dvd and appears to work perfectly.:)
  3. Sick Boy
    Sick Boy
    Aug 27, 2003
    2,091
    Bristol
    +138
    Don't see why you would have any problems with the 2010. It is a learning remote so does not rely on any codes.
    Did have problems learning 4 sky buttons but I think they are a problem to all LR's. Solved that now anyway.
    I would go for a Epilot as mentioned by Mylo as at £29.99 you cant go wrong. I've had the 2010 for a while and it cost £70 from Maplins then. Half price eh! :confused:
