Srange problem during gameplay
Discussion in 'Xbox Forums' started by John, Sep 6, 2007.
  1. John
    John
    Dec 13, 2002
    11,635
    +3,304
    Hi Guys
    My Xbox seems to have developed a strange problem during gameplay . The Xbox seems to forget what its supposed to do with the controller input
    For example
    During PGR2 it will be fine , then all of a sudden it will forget to change up gear until such point as you can only move in reverse . A change of controller or controller port has no effect . Hit IGR to reboot and the controller still won't work ,save for a few buttons . turn it off and on again at the console and all back to normal :confused:.
    There seems to be no regularity to it . It could be a minute into a game or 60 .
    Anyone heard of this before ?
    Using XBMC pre2.1 (compiled : AUG 13 2007) , with the great MC360 as its skin ;) . Games booted from HD
    John
  2. John
    John
    Dec 13, 2002
    11,635
    +3,304
    For the record , it turns out it was just a controller problem . Having to use a DUKE . No wonder they ditched them in favour of the "S"'s
