SR5400 Q's
Discussion in 'AV Receivers & Amplifiers' started by revo, Jan 10, 2004.
  1. revo
    revo
    Jan 10, 2004
    38
    9
    Does anyone know..
    If you can assign the digital inputs 1-4 to the video input connections, rgb 1 + 2?
    Does the SR5400 upward convert s-video input to RGB monitor out, leaving only the need for a single monitor connection?
    What is the best matching DVD player for this AMP, where the preference is the same make for remote control utilisation.
    Clive
  2. keylion
    keylion
    Oct 13, 2002
    208
    Lancashire
    +9
    Not sure about assigning the audio to the video inputs (doesn't seem to be any reference to it in the manual or on the on-screen set-up menus) but on the upconversion it looks like this can't be done. An extract from the manual as follows:
    "Each type of video jack works independantly. Signals input to the Composite and S-Video jacks or Component are output to the corresponding Video, S-Video and Component jacks respectivley".
    Unfortunately I can't check this as I don't have any Component based sources.
    KL
