SR+ control cable ???
Discussion in 'Plasma TVs Forum' started by dvdsubtitles, Sep 6, 2004.
  1. dvdsubtitles
    dvdsubtitles
    Hi all,
    My PDP-504HDE has arrived and I am a very happy bunny :)
    I have it married up to a VSX-D814 AV receiver. However, in order to enable the receiver to switch audio inputs depending on the TV input, I need to use a control cable between the 504's media box and the receiver. Ie. a miniplug cable from "CONTROL OUT" on the media box to "CONTROL IN" on the receiver. This will supposedly allow the TV to control the amp, switch inputs, etc.
    The 504 instructions refer a "control cable" and the receiver instructions refer to a "SR+ cable". A standard 3.5mm jack lead fits perfectly, but it does not work.
    Does anybody have a similar setup and is it some very unusual cable that I need?
    Hope you can help.
    Mat
  2. mikeycrawford
    mikeycrawford
    Nov 27, 2002
    116
    I have the same setup, but I thought all the SR+ cable did was allow the IR of the amp remote to pass through the IR receiver on the plasma screen.
    This needs some investigating methinks
  3. dvdsubtitles
    dvdsubtitles
    Yes, instructions are somewhat vague, but this is what I've gathered from my fiddling and research so far:
    features available using SR+ control cable:
    * receiver switches on when tv is switched on
    * receiver switches audio inputs when tv switches inputs (ie. switching between DVD/digital box/xbox etc.)
    * receiver display shown on tv screen.
    I've just been told by my dealer that its a 2.5mm jack plug. However, I've tried a 3.5mm jack plug which fits perfectly but does not work. I can't believe a 2.5mm plug would fit properly if a 3.5mm does??
    Mat
  4. sraper
    sraper
    Aug 7, 2001
    749
    46
    Watford, UK
    +230
    Hi, I have a similar setup a 504HDE connected to a VSX-D912. So I am only using SR and not SR+. This uses a normal 3.5 "Mono" connector. I bought a few from MaplinMaplin about 80p each for a simple 1.5 metre lead. All this does is to allow the remote sensor on the plasma to send signals to the amp, and indeed any other Pioneer kit that you may have. Someone else here was asking a similar question and said that a 4-pole 3.5 mm phone plug is used for SR+. However I don't know what the extra features are available.
