sr 7300
Discussion in 'AV Receivers & Amplifiers' started by MarkEmmett, Dec 27, 2002.
  1. MarkEmmett
    MarkEmmett
    Could anybody with a sr 7300 amp be as kind to do a front to back accurate measuremet including the 2 knobs at the front as I would like to purchase one of these but have only a limited depth in which to mount it I have seen various measurement that are a bit conflicting.
    Thanks Mark
  2. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Download the manual from here
    It gives the measurements you require. I can't be bothered to measure mine. I don't have a lot to compare it to but it sounds good to me. I would suggest you carefully consider the 5300 or 6300 as well though, I'm not convinced there is a huge amount of difference in the sound they produce.
  3. MarkEmmett
    MarkEmmett
    Thanks Daneel I will download that file and find out the size I will look into the 6300 as you said to see if their is much difference BTW what is the differnce in cost between the two.
    Thanks Mark
