I installed SqueezeCenter 7.3.2 on a pc with Vista Business pro. The pc is connected by wifi to a netgear WRT54GL and the squeezebox. The 1st time i installed it i hadnt set up any wifi security and it started fine. I then added some WEP security to the router. Pc and squeezebox connected fine. I restarted the pc and SqueezeCenter wouldnt start, it just stayed in a "Starting" state. Removed the WEP security and rebooted everything but it still wouldnt start.
Did a complete clean install following this guide with WEP on before hand and it wouldnt start at all after installation
Removed it and the WEP again, restarted and reinstalled squeezecenter. It started properly. Rebooted pc and it started properly again. Turned WEP on again and rebooted pc. It didnt start at all. Removed WEP and rebooted but again it wouldnt start.
I'm at a complete loss. *** wont it start with WEP security? Why do i need to do a full clean install to get it working without security? I disabled the installed norton firewall and it didnt effect it. Had set norton to give it full permissions too.
