Squeezebox3 -> NAS
stevos
Does any one know how to get a squeezebox3 to work with a NAS drive, and which drives are supported?
Steve.
stevos
Will check them out, cheers for the help
stevos
I have purchased a Buffalo LinkStation and i am now awaiting delivery.
Out of interest how much damage can i do if i mess up the installation of slimserver, can it be reset to default if i get it wrong?
stevos
P.s. does anyone have a copy of firmware version 1.45 that they could email me?
stevos
Right i am following through the instructions at http://www.audiofi.co.uk/reviews/sb3.html.
On page to it states type telnet followed by the ip address, so in my case i typed
telnet 192.168.1.10
it is then meant to access the linkstation, i however get the following error.
could not open connection to the host, on port 23: Connect failed
i have version 2.05 of the firmware.
Any idea?
andrew1810
In a command prompt, try typing "ping 192.168.1.10"
That should come up saying "reply from...."
Let me know if that works and I'll take it from there
stevos
it states 4 packets sent, 4 recieved, none lost.
stevos
Cheers for your help, i think i will need to look at this with the light of day. One last thing, how do i know which processor the linkstation has to choose which version of the firmware i need?
stevos
Cheers you have been loads of help. Hopefully i won't need any more help, but if i do i know where to find you.
Steve.
avanzato
I've flashed mine to the Openlink firmware with no problems. IIRC you can reset the 'system' by re-flashing if you mess up the Server install. I haven't installed a server yet as the Twonky installer didn't work automatically and then i decided the linkstation worked just fine as a shared network folder. From what I've read my LS has a slightly different file structure to some of the instructions for installing Twonky. I'm not sure if that will make a difference to the Slimserver install as well or not.
stevos
okay flashed it with openlink firmware using the installer linked above.
I downloaded 2 files, it seemed to only use the zip file.
When i use telnet it comes up with
bash-2.05a# 06
and asks for an input
nothing about password and username.
I can still access the shared folder, so i haven't broken it yet.
and idea?
stevos
okay cool, slowly getting there.
How do i actually log into root.
When i type telnet 192.168.1.10 it takes me in, am i missing something?
I am at the point of trying to copy the new version of perl and have typed
cp /mnt/name-of-network-share/perl-5.8.5-linkstation.tar.gz /
which states no such file or directory, any ideas?
stevos
I think i know whats wrong, what is the unix equiv for the windows dir?
i.e. listing out the contents of a directory.
stevos
never mind worked it out thanks to google, was missing the hda directory
stevos
One step forward and i have now got stuck again, grrr
I need to uncompress the perl file, so typed
tar xzvf perl-5.8.5-linkstation.tar.gz
but get the following error.
tar (child): perl-5.8.5-linkstation.tar.gz: Cannot open: No such file or directo
ry
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
bash-2.05a#
bash-2.05a#
However the file is there, so i have no idea what to do now.
pete0
can't remember what the 'z' option is but it may be you need to unzip the .gz file first ...
gunzip perl-5.8.5-linkstation.tar.gz
stevos
afraid not
pete0
ah, that's what the z option is for.
Apologies if you're gone through this but try...
pwd #show current dir
ls perl*
to check that your file is in the directory you currently in.
Similar threads
Trending threads
Latest News
Toshiba launches UK4B 4K Alexa enabled TV
  • By Andy Bassett
  • Published
Mulan to premiere on Disney+ on 4th September
  • By Andy Bassett
  • Published
Has Amazon Prime Video dropped Dolby Atmos?
  • By Andy Bassett
  • Published
JBL launches 4349 Studio Monitor
  • By Andy Bassett
  • Published
