wytco0
Established Member
I am Continuing my search for a audio streaming solution for my new house. I have been looking at Squeezebox (which i use now) and Sonos. I was planning to stick with Squeezebox but they do not seem to have the products I need at the moment as they have discontinued the Boom without a replacement.
I can do everything by moving to Sonos but its and expensive solution and I think that the Touch is a better product that the connect for my main hifi system (Lyngdorf/Quad electrostaics). So I am thinking of using both with a single touch and a number of Play 3 and 5s for the rest of the house. I know that this means I wont be able to sync to all systems but this isnt a problem for my HiFi system.
Does anyone run both of these systems together? My music library is FLAC on a NAS. Do both servers run together without any problems?
Last question, the touch with a couple of simple Active speakers would be a decent solution for a quality sound system in a smaller room, are there any decent quality small active speakers that I should be investigating?? is might give me a way of staying Squeezebox only.
