Squeezebox radio.
Discussion in 'Video Streaming Boxes & Services' started by lynx, Sep 5, 2012.
  1. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    I can't connect my squeezebox radio to my wireless network. Entering the netwok key results in a message informing me it is unable to connect (pc, tablets etc are all connecting ok).
    In newtork health, it is reporting no link.
    Wireless info - not connected.
    Any ideas?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,515
    Rainham Essex
    +2,515
    I think you will get a better response getting this thread moved to the music streamer forum - Streamers & Network Music Players | AVForums.com - UK Online
    This forum section is for video streamers so you may not get those that know most about the Squeezebox players visiting here.
    I have however got a SB Duet and I had similar issues getting mine setup. I found the easiest way to get it connected was to do a full factory reset and then try setting it up from scratch.
    Probably also worth disabling any firewall program on the PC running the server software just in case that is blocking your connection. If that helps then look at whitelisting your SB Radio and or the SB software.
    Mark.
  3. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    Issue has resolved its-self.
