squeezebox duet help
spb251272
Established Member
You need to dl a cd ripper and save to the file format you want eg mp3 or flac. I think a lot of people use EAC but there are free ones as well
HeadBanger
If you want a simple solution then download Microsoft's Windows Media. It's free (as long as all your existing MS software is genuine) and will rip your cd's and create a library for you. Once done you will then need to tell the Squeezebox Server (running on your laptop) where your new music library is stored (e.g. C:\My documents\My Music) in order for it to be able to stream it to your Duet's receiver.
If you want something a bit more advanced but still free then try Foobar 2000 (note all codecs have to be downloaded seperately and stored within its components folder for Foobar to use).
HTH
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
