Squeezebox Classic problem
Discussion in 'Music Streamers' started by Beko, Feb 12, 2009.
  1. Beko
    Beko
    Feb 11, 2009
    14
    Just wondering if anyone has had a problem where the screen (or maybe its the whole system) doesnt turn on, it doesnt react in anyway, its plugged in and i can see a red light behind it so it should be getting current, but it just doesnt turn on =/
  2. t-force
    t-force
    May 2, 2001
    1,873
    Southampton, UK
    +154
    Have you tried cycling the power? Unplug the AC adapter, leave it for 20 secs or so, then reconnect.
  3. Beko
    Beko
    Feb 11, 2009
    14
    yeah, its been unplugged for hours now, nothing happens, i tried the factory reset too
  4. Member 7321
    Member 7321
    Mar 28, 2001
    208
    Heathrow/Warrington
    +19
    Sounds like it has died, where did you buy it from and when?
  5. Beko
    Beko
    Feb 11, 2009
    14
    Got it from Pc world at least a year ago, it hadnt been used for quite some timewhen i tried it recently.
    Could it be the remote? is there anyway to turn it on without the remote just to try?
  6. glenlevisohn
    glenlevisohn
    Apr 26, 2006
    78
    +16
    You should be able to turn it on from the web browser http://server:9000
  7. Beko
    Beko
    Feb 11, 2009
    14
    the squeezebox isnt set up for this wifi though :(
  8. Paden
    Paden
    Jul 27, 2000
    580
    +26
    I had my router unplugged earlier & the display on my Classic went out when it lost it's wireless connection, perhaps that's you problem.
    Maybe if you try a cable connection to your router temporarily, it might burst into life?
    Cheers, Paul
  9. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    You can check any IR remote by looking at the wee emitter through a camera LCD viewfinder, pointing at the emitter and pressing some buttons can show a light at the emitter. Even phones sometimes work fine for this.
    If you power cycle it, or do factory reset by power cycling and holding down the 'add' button, it the display should show the Squeezebox splash screen as it powers up.
    I had a wireless SB3 that died with the same sypmtoms as you, at the time there was chatter on the Slim forum about pulling the wifi card, which I did and the sb3 sprang back into life, albeit it can now only be used wired via ethernet.
    Maybe worth a try to recover your situation. You'll need a small Torx screwdriver to open the back of the case, but its all pretty simple stuff annd should be fairly obvious.
    If all else fails contact Slim/Logitech and you can get it repaired in the US.
    Good luck.
