Squeezebox Classic on Sub
scrufftyguy
Hi, I'm considering getting a squeezebox classic, but the only place I can fit it is on my subwoofer! Has anyone else got there's on their sub, or is their any reason why I shouldn't keep it there? The Duet would fit nicely in my HiFi rack, but I'm wanting to control it with my harmony remote, so I've started leaning towards the classic. Cheers! :thumbsup:
deaf cat
I've mine bluetacked to the the top of a speaker, not ideal as IMO vibration of components affects the sound repro, but, at the moment thats the only place it can go... so that is where it is.
:rolleyes:
scrufftyguy
That's got me concerned! I could get another shelf for my rack @ £70, but I don't really want the extra expense! :)
amcluesent
Cut some squash-balls in half and sit on top.
coolio107
:rolleyes:
Vibrations?
You seriously care about VIBRATIONS when you've got it sitting on top of a speaker with all the EM noise that will feed into your power supply?
You are kidding?
Not that _I_ believe you will actually HEAR any of these issues...
scrufftyguy
So is it likely to be much of a problem? :confused: I'm guessing that there's nothing in the squeezebox that could be screwed up by the magnet in the sub's speaker? If it just rattles it about a bit I can live with that for now!
coolio107
Sorry if my comment was confusing, just read the last line.
I don't think you will have any issues, was just trying to mock about the comment that that vibrations could affect the sound quality.
scrufftyguy
Thanks everyone, think I might take the plunge and get one soon then! :thumbsup:
nacmacfeegle
They are quite small and light, so other options abound. I have one wall mounted above an lcd tv in my kithchen and Ihaven't noticed anything interfering with it...apart from the SWIMBO.....
