Squeezbox - Phono cables or Optical
largesack
stereo interconnects....i think really this is the only way to go...the SB has 24bit burr brown DACS, unless you have an extremely high quality amplifier or a decent external DAC, sound quality will be lost
sennen
I use optical, into an Onkyo 715 plus a pair of Q 1010, in a kitchen/dining room, with both compressed and uncompressed music.
I didn't notice any real difference between optical and phono in the small amount of testing I did (but bear in mind the level of equipment and room type).
I read that the Onkyo amplifier is digital, so it seemed a reasonable idea to use the digital input to avoid extra D/A and A/D conversion.
HTH
3sgte_power
The Onkyo 875, which is what i have has analogue in, so really it should digitize the sound, just amplify it and use the DAC in the SB3.
amcluesent
Most AV Receivers digitise all their inputs so they can apply DSP.
If yours is like that, you may as well use S/PDIF from the sqeezeboz since you'll be listening to the DAC in the receiver anyways.
Zarch
Chaps,
What cables come with the Squeezebox? (phono, spdif or coax?)
I've just ordered mine, should be here in a few days, just wanna check that i don't need to go and source some cabling to connect to the amp.
Hades
Chaps,
Phono cable in the SB3 box.
Mr_Sukebe
Try both and see which you prefer.
With an AV amp, I'd be surprised if you could tell the difference.
Zarch
Please excuse my obvious ignorance, but what is the difference between standard phono cables and digital coax optical?
I take it i can't use standard phono cables in the optical socket to my amp? Is there something inherently different inside the cables?
If so, i'll be off to maplins at lunchtime! :smashin:
Autopilot
They are completely different cable systems, with one being digital one being analogue. I dont think that question can be fully answered in a forum thread, hit google and do some research (if your AMP has coax input).
Zarch
Thanks autopilot, i assumed there was something completley different about them, but thought i'd check. Cheers.
Cynar
One of the main reasons for the high cost and high quality sound of the Squeezebox is the inclusion of the expensive 24 bit Burr Brown DACS.
If you connect it digitally, you're bypassing them and using whatever DAC is in your receiver.
If your receiver has an inferior quality DAC (very likely with most mass market stuff) sound quality won't be as good.
If your receiver has higher quality DACs then sound quality will be better.
Either way it seems a bit pointless paying extra for the DACs then not using them!
Mr_Sukebe
If you're talking about optical cables, well they do use fibre optic glass for transmission of light waves as against standard cables, which pass electrical data over usually copper wire.
