Squeaking speakers!
Discussion in 'Home Cinema Buying & Building' started by jarr, Jan 12, 2008.
  1. jarr
    jarr
    Dec 4, 2007
    I have a panny 450 home cinema connected to sky hd vial audio leads. (no optical) Cinema and sky to tv via hdmi
    when i play regular movies all speakers are fine but when i play sound on sky tv via speakers the rear surround speakers have a slight high pitched squeaking. not very loud but shouldn't be there at all!
  2. jarr
    jarr
    Dec 4, 2007
    Seems more people are concerned with 550 and 850:oops:
  3. jarr
    jarr
    Dec 4, 2007
    Help, please? New TV, Sky HD and Homecinema and it doesn't work properly!
    :lease:
  4. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Are the connectors pushed fully home ?
    Have you tried different leads?
    Have you tried pulling off one at the time to hear which channel is causing it?
  5. jarr
    jarr
    Dec 4, 2007
    Because it has no optical socket I had to uses normal leads. Audio leads? Two in SkyHD two in HC, that is correct? There are 3 sockets why is this?
  6. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    The 3 sockets are component (red green blue) video
    You need the 2 Audio (red/white)
    Are you sure you are not using the white audio AND the red component video by mistake ????
  7. jarr
    jarr
    Dec 4, 2007
    I'm using a Scart now and it's still slightly there.
  8. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Sounds like it has a fault then :thumbsdow
  9. hilly7
    hilly7
    Dec 4, 2007
    I think i am getting the same sound on my LG HR902TA system. Fine playing DVD's but when i use SKY and i have on certain sound settings i get squealing in the rear speakers. If i have the rear speakers on constantly then i dont get the noise. Does this sound the same?
  10. gmp
    gmp
    Mar 23, 2006
    479
    28
    +47
    If your DVD's are fine (playing in 5.1 with no squeeks) then it could just be the unit struggling with pro-logic decoding a stereo source. I used to have an old system that used to do same when fed a stereo source and tried to use surround/pro-logic effects. It was fine with 5.1 from dvd and optical inputs but with stereo input there was always a low volume squealy/squeeky noise underpinning what else was coming from surrounds.
  11. oddman76
    oddman76
    Jan 4, 2008
    137
    +16
    yeah I have the same when using prologic for stereo tv through digi box but it is not noticable if you are not listening for it ...I use the ht-ddw790
