Spyware problems !
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Apr 18, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    My Father in Law has 2 computers (Laptop and Desktop) that are conected to a router which is then connected to broadband. The router has all the firewalls and pop-up blockers selected.
    But still he gets the spyware installed onto both computers. I've used Adaware to clean them both a couple of times before but they keep coming back.
    I tried once more to get rid of the spyware last night, but the Desktop was so slow that after completing the search and comiling the data, it stopped and the Laptop stopped completely when it hit the 45,000 mark (Normally c120,000).
    The router has stopped connecting to the internet now so I can't get and update from the website.
    Can someone suggest:
    1. A piece of software to download an completely clean his computers.
    2. A piece of software to the will protect his system from Spyware. Currently Yahoo doesn't seem to be bothered doing anything.
    3. A website that tell you about router settings. I've had the router connected before but it seems to drop out every now and again. It's one from Maplins that cost about £70.
    Thanks,
    Richie.
  2. Grumble
    Grumble
    Mar 16, 2005
    220
    17
    St. Andrews, Fife
    +82
    Hi Richie
    I use Webroot Spy Sweeper to protect my system.
    http://www.webroot.com/
    I also find my router drops the ADSL connection occassionally, I think this due to BT resetting my broadband connection (usually done in the small hours).
    You should be able to set the router to re-connect automatically, when this happens.
    Have you tried the router manufacturer's website for details on how to set it up?
  3. Tupo
    Tupo
    Nov 2, 2004
    248
    43
    +146
    I too use webroot spysweeper.
    Without a doubt the best spyware solution there is.
    And for virus protection try NOD32.
    With both nod and sweeper you will have no problems :smashin:
    And that is coming from someone that used to be inundated with spyware attacks etc.
    Now Im as safe as a fisherman with a johnny on :clap: :clap:
  4. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
  5. jon stallard
    jon stallard
    Your father in law should also switch to Mozilla Firefox as his browser. This is almost as good as a decent spyware program. Another good program is Prevx. http://www.prevx.com/ It's another free jobbie. Read what it says it does on the website.
  6. mrwhippyrulez
    mrwhippyrulez
    Apr 6, 2005
    16
    Thoroughly recommend the Microsoft AntiSpyware, even though it is currently only a Beta version. It has found and effortlessly removed spyware which other products, (inc Spybot), in my experience, either couldn't find or clean properly
    For free they don't come much better, it will also protect your system from further infection if you want it to.
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    The single most important prevention is not to use Internet Explorer or Outlook Express, use Firefox and Thunderbird and you'll likely never see a single piece of spyware.
    As for spyware removers, there's no single solution, they all miss some. M$ is at least free, but of course their interest should be writing software that's not vulnerable, not producing something to tidy up the mess they helped create in the first place.
  8. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    Disable Java in his browser, use a browser which allows you to stop sites installing software automatically (firefox lets you specify this).
    I also use a proxy that disarms/modifies a large number of javascript 'baddies'.
    Set up a good hosts file on the PC (and keep it updated).
    Sweep for ads/virii/spyware/ regulary.
    Only allow cookies that want to be dropped on you.
    Keep all the above up to date.
    Securing and maintaining widoze is a PITA.
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    And of course ensure his system is patched up to date.
    For A/V I use NOD32, about the most reliable according to "Virus Bulletin" tests over several years.
  10. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Actually, the "single most important prevention" KraGorn, is not to use Windows at all - critters in the woods just love the sweetness of Sequoia Sempervirens :devil: .
    Seriously though, I would try CWShredder to remove the parasites and then set-up IE-SpyAd.
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Switching to Linux or a Mac isn probably not an option. ;)
  12. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
  13. Leporello
    Leporello
    Perhaps I missed something but I'm not sure about about the Microsoft Antispyware beta. I have Adaware installed. When I run the Microsoft program nothing is found, if I then run Adaware it usually finds up to 20 items of spyware.
  14. sniffer66
    sniffer66
    May 22, 2004
    9,844
    +3,579
    I'd also recommend a local desktop firewall rather than relying on the router. Sygate is excellent and there is a free version
