spyware is killing my pc
Discussion in 'Desktop & Laptop Computers Forum' started by tightjock, Dec 17, 2004.
  1. tightjock
    tightjock
    hi looking for free spyware removal downloads, can you help.regards
  2. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Most common recommendations are adaware, spybot and spywareblaster.
    Use all three together, if you do a search here you'll find loads of info about spyware removal.
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    How do you know if you're suffering?
  4. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Generally computer running slow, network connection running slow, if you're running a download meter lots of traffic when you're not on the net (although that can just be file sharing if you're running it).
    Have a look in the task manager to processes you don't know (if you've never looked at that there's be lots of them, that's normal).
    If you run a command prompt and type "netstat -a" you can look for open ports that you don't know about.
    Have a quick google for "spyware faq" and you'll turn up hundreds. Just remember to only download recommended programs as half the spyware removal tools will be spyware themselves!
  5. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    you can get search and destroy from hereand adaware from here
  6. Leporello
    Leporello
    I think Adaware SE is a terric little freeware spyware remover. I've also used Spybot which is also good but a little more cumbersome than Adaware. Type Adaware into google and you'll be there.
  7. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    you dont need to do a google just follow the 2 links ive giving you and there are there
