delboyuk2005uk
Established Member
Need rid asap nice and easy software to do this please help?
- Spybot
- Malwarebytes (never used this myself, but people are raving about it)
- Ad-Aware
- Windows Defender
- SpywareBlaster (prevents spyware from installing)
Remember to update them once install, and scan and remove in safe mode.
You can also not visit porn sites, that usually stops spyware from getting on your machine![]()
Hmmmm, source/proof?Windows Defender is spyware, it reports all sort of stuff back to MS and actively monitors peer to peer / torrent software usage and what files you have downloaded generally.
Don't join spynet then!
