spv m2000 info needed
Discussion in 'Mobile Phones Forum' started by Rindless, Jun 25, 2005.
  1. Rindless
    Rindless
    Dec 15, 2001
    680
    +4
    i want to use this phone/pocket pc as a proper multi media player and want to know EVERYTHING about the best programs I can install, so I can view movies using the entire screen in landscape mode.
    Thanks.
  2. Rindless
    Rindless
    Dec 15, 2001
    680
    +4
    So nobody has this pocket pc then :-(
  3. hyster
    hyster
    Nov 21, 2004
    113
    +3
    If you want to view movies on your pda then DVD TO PDA POCKET PC will do that , you will need a big flash card though.google for it.
    hope this helps,
    regards Hyster
