spv aeroplane mode
Discussion in 'Mobile Phones Forum' started by krusty, Apr 17, 2005.
  1. krusty
    krusty
    somebody has been messing with my phone[spv] and set the phone to aeroplane mode....how do i get it back to normal?
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,334
    +6,868
    If this is a Windows 2003 device like the XDA, then the phone aerial/connection icon at the top of the screen (next to the speaker icon) will have an "x" next to it. Simply tap the icon & select "Turn off flight mode".
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    If you're using a Smartphone device, just press the power button (don't hold, that will turn the phone off hehe) and select the option to turn flight mode off. On the C500 it's option 2, can't remember what it is on 2002 edition!
  4. krusty
    krusty
    thanks , got it sorted.
  5. Dr.Roboto
    Dr.Roboto
    hi krusty, ive tried sending you pm's a couple of times but your mail box is always full,
    can you delete a few old messages? it wont let me reply to your messages until you delete some old ones
